PROBLEM
The Update a Feature output connector creates multiple features for a common unique identifier in ArcGIS GeoEvent Extension for Server
The Update a Feature output connector in ArcGIS GeoEvent Extension for Server allows users to feed real-time data to an existing feature service. In some instances, using the output connector adds multiple records to a common unique identifier, instead of updating the existing record.
Cause
This is a known limitation. The issue occurs when sending a batch of updates to a common feature using the Update a Feature output connector.
Solution or Workaround
The following are the workarounds for this issue:
  • Send updates one record at a time
When updating features in a feature service, send the records one at a time instead of batch updates. This prevents multiple items being present for a common unique identifier in the real-time update data.
  • Use stream services
Use a stream service instead of a feature service. This issue is not reproducible in stream services. Unlike feature services, a stream service allows real-time data dissemination with low latency. For more information on creating and publishing stream services, refer to ArcGIS for Server: Publishing a Stream Service.
Article ID: 000013101
Software:
  • ArcGIS Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
