PROBLEM
The top-level color property of this symbol is locked when changing the symbology color in ArcGIS Pro
Last Published: March 19, 2024
In ArcGIS Pro, the fill color of a symbol can be changed by right-clicking the symbol under the layer in the Contents pane to open the color palette. However, in some instances, attempting to open the color palette returns the following message:
Error:
The top-level color property of this symbol is locked. Open the symbol in the Symbology pane to change the color of individual symbol layers.
The message returned when attempting to change the symbology color in ArcGIS Pro
Cause
The top level color property of the symbol is locked in the Symbology pane and no edits can be made.
Image of the locked color symbol
Solution or Workaround
  1. In ArcGIS Pro, right-click the layer in the Contents pane > Symbology.
  2. In the Symbology pane, click the symbol to open the Format Symbol mode. In this example, the Format Point Symbol pane is opened.
Clicking the symbol in the Symbology pane to open the Format Symbol mode
  1. In the Format Symbol mode of the Symbology pane, click the Properties tab > Layers.
  2. Click Layer colors are locked The Layer colors are locked icon to unlock the layer properties. Ensure the button is labeled Layer colors are unlocked and click Apply.
Unlocking the top color layer in the Symbology pane
The image below shows the color palette displayed after right-clicking the symbol in the Contents pane.
The color palette displayed when right clicking the symbol in the Contents pane
Article ID: 000032206
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
