PROBLEM
When opening a tile layer in ArcGIS Online Map Viewer, the tile layer is not visible on the map.
The level of detail (LOD) of the tile configuration is too low for the tile layer to be visible. The LOD represents the zoom level for a map view or scene view and displays various levels of details based on the configured LOD, where lower levels are furthest from the earth with smaller scales, while higher levels are closer to the earth with larger scales, and can zoom in to the extent of streets, buildings, and houses.
The image below shows the tile layer is now visible in ArcGIS Online Map Viewer.
Article ID: 000031377
Get help from ArcGIS experts
Start chatting now
