PROBLEM
In ArcGIS Experience Builder, adding dynamic text to an app is possible using the Text widget. The data source for dynamic text is based on attributes from multiple feature layers. For example, a sentence is combined with one or more fields to populate values from selected features in the connected data, as shown in the image below.
However, it is not possible for the Text widget to list multiple records of the data. Adding a second Text widget does not display subsequent attribute records as well.
This is by design. As soon as the Text widget is connected to the data, only one record can be used as a field name variable to display the attribute values.
Configure the Text widget in the List widget to display multiple attribute records for the dynamic data.
button to display the Dynamic content panel.
Note: Optionally, use the List widget's Sort tool to display the records by specific fields and sequence.
The image below shows multiple records of the data from the List widget.
Article ID: 000028724
Get help from ArcGIS experts
Start chatting now
