PROBLEM
If a one-to-one extended property table is imported to a Workflow Manager repository, for which the owner name and table name match an existing table in an upgraded Enterprise geodatabase, Workflow Manager treats it as two, separate tables. However, a conflict can occur if both tables are configured to the same job type, which causes the following error to display when the user creates a job using the job template:
Error Extended (one-to-one) properties already exist for this job.
Starting at version 11.0, Enterprise geodatabase system tables no longer store the database name as part of the fully qualified name in ArcGIS applications. For example, dbname.ownername.tablename becomes ownername.tablename.
If a table in an upgraded Enterprise geodatabase matches an existing one-to-one extended property table in a Workflow Manager repository, restore the Workflow Manager configuration by removing the duplicated extended property table.
Article ID: 000028699
Get help from ArcGIS experts
Start chatting now
