PROBLEM
The symbology in ArcGIS Online Map Viewer is not retained in ArcGIS Web AppBuilder
Last Published: May 3, 2023
Certain symbologies created in ArcGIS Online Map Viewer are not retained in ArcGIS Web AppBuilder.
The images below show the symbology of a hosted feature layer in ArcGIS Online Map Viewer and ArcGIS Web AppBuilder.
In ArcGIS Online Map Viewer
Custom symbology in a web map in ArcGIS Online Map Viewer.
In ArcGIS Web AppBuilder
Custom symbology in a web map in ArcGIS Web AppBuilder.
Cause
This is a known limitation. The symbologies created in ArcGIS Online Map Viewer are not supported by ArcGIS API for JavaScript 3.x used by ArcGIS Web AppBuilder. This is because ArcGIS API for JavaScript 3.x is currently in the Extended Support Phase and is retiring on July 1, 2024, as well as its clients, including ArcGIS Web AppBuilder. Refer to ArcGIS Web AppBuilder: Release versions for more information. Hence, no updates and enhancement are made on the older platforms, so advanced symbologies created in Map Viewer are not available in ArcGIS Web AppBuilder. Refer to Technical Support: ArcGIS Maps SDK for JavaScript Life Cycle for more information.
Solution or Workaround
Use compatible symbology styles in Map Viewer
When configuring a web map in Map Viewer, use basic symbology styles. These styles are supported by ArcGIS API for JavaScript 3.x and is retained in ArcGIS Web AppBuilder.
Symbol style pane in ArcGIS Online Map Viewer.
Use ArcGIS Experience Builder
As an alternative to retain the original symbologies, open the web map in ArcGIS Experience Builder instead. Refer to ArcGIS Online: Create apps from maps for further instructions. ArcGIS Experience Builder runs on ArcGIS Maps SDK for JavaScript 4.x and is planned to reach most of the functional parity of ArcGIS Web AppBuilder along with more advanced features through incremental releases.
Article ID: 000029993
Software:
  • ArcGIS Web AppBuilder
  • ArcGIS Online
  • ArcGIS Experience Builder
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
