PROBLEM
In some instances, the Summary widget in ArcGIS Web AppBuilder returns incorrect results for hosted feature layers though the attribute tables contain the required values.
The image below displays an example of an incorrect result returned by the Summary widget.
This issue occurs when a map is published from ArcGIS Pro with empty geometry or when records in a feature layer have invalid or missing geometry formats. Refer to ArcGIS Pro: Origins of bad geometry for more information.
Use one of the methods below to resolve the issue.
Run the Check Geometry and Repair Geometry tools
In ArcGIS Pro, run the Check Geometry (Data Management) and Repair Geometry (Data Management) tools before republishing the map. Refer to ArcGIS Pro: Check Geometry (Data Management) and ArcGIS Pro: Repair Geometry (Data Management) for more information.
Use the Replace Geometry tool
In ArcGIS Pro, use the Replace Geometry tool to replace features with invalid or missing geometry. Refer to ArcGIS Pro: Replace feature geometry for instructions.
Article ID: 000025845
Get help from ArcGIS experts
Start chatting now
