PROBLEM
In the ArcGIS Server Manager View Logs page, the Source selection box is not populated with available services. Due to the missing services, the Query button is disabled.
The value of the number of services is higher than the value for the adminConfig.maxSourcesSelectionForLog parameter set in the admin.js file for ArcGIS Server manager. By default, the value of the parameter is 100. Services stop displaying in the source selection when the maximum number set as the value of the adminConfig.maxSourcesSelectionForLog parameter is exceeded.
To check the number of services available, if there is a large number of services involved, use the developer tool in the browser to access the log page. The following procedure is performed on the Google Chrome browser.
Warning: The instructions below include making changes to essential parts of the software. Esri recommends performing a backup of the files before proceeding. Esri cannot guarantee results from incorrect modifications while following these instructions. Exercise caution. Contact Esri Support if necessary.
C:\Program Files\ArcGIS\Server\framework\webapps\arcgis#manager\js\esri\discovery
Article ID: 000027399
Get help from ArcGIS experts
Start chatting now
