PROBLEM
The Sign In option is not available on the ArcGIS Enterprise portal
Last Published: September 28, 2021
In some instances, when attempting to log in to Portal for ArcGIS configured with Integrated Windows Authentication (IWA), the Sign In option is not available on the portal's home page, as shown in the image below.
The Sign In option is unavailable on the ArcGIS Enterprise portal's home interface page
Cause
The user account is not a member of the portal.
Solution or Workaround
The following workaround may require the assistance of a system administrator. Consult a qualified computer systems professional if necessary.
When using IWA, logins are managed through Microsoft Windows Active Directory. To resolve the issue, add the user account as a member of the portal, followed by enabling anonymous authentication on the ArcGIS Server site.
  1. Add the account from the related identity provider as a member of the organization's portal. Refer to Portal for ArcGIS: Add accounts using the portal for steps to do so.
  2. On the ArcGIS Server site, disable IWA to allow the site to read the portal's users and roles from IWA. Refer to Portal for ArcGIS: Configure your portal to use IWA for more information.
  3. On the ArcGIS Enterprise portal's home page, click the Sign In option, and log in to the portal using the provided credentials.
Article ID: 000025130
Software:
  • Portal for ArcGIS
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
