PROBLEM
The Share Web Tool and Overwrite Web Tool functions are unavailable in ArcGIS Pro
First Published: September 30, 2022
Last Published: September 30, 2022
In ArcGIS Pro, web tools can be used to share analysis with others users in an ArcGIS Enterprise portal. Web tools are first created and run in ArcGIS Pro before being shared to a portal. In addition to sharing new web tools, existing web tools in a portal can be overwritten to reflect changes. However, in some instances, when attempting to share or overwrite a web tool from ArcGIS Pro, the Share Web Tool and Overwrite Web Tool functions are unavailable.
The Share Web Tool and Overwrite Web Tool functions are unavailable when accessed from the Share tab and the History pane.
The Share tab in ArcGIS Pro and the unavailable Share Web Tool and Overwrite Web Tool functions.
The History pane in ArcGIS Pro and the unavailable Share Web Tool and Overwrite Web Tool functions.
Cause
The user is logged in to ArcGIS Pro using an ArcGIS Online account instead of an ArcGIS Enterprise account.
Solution or Workaround
An ArcGIS Enterprise account is required to access the Share Web Tool and Overwrite Web Tool functions. Log in to ArcGIS Pro using an ArcGIS Enterprise account instead of an ArcGIS Online account to resolve the issue. Refer to Portal for ArcGIS: Use ArcGIS Pro with your portal for further instructions.
Additionally, ensure the Publish web tools administrative privilege is enabled for the portal account to successfully run the functions. Refer to Portal for ArcGIS: Administrative privileges for more information.
The Publish web tools administrative privilege under member roles settings.
After logging in with a portal account in ArcGIS Pro, the Share Web Tool and Overwrite Web Tool functions are available when accessed from both the Share tab and the History pane.
The Share tab in ArcGIS Pro with the Share Web Tool and Overwrite Web Tool functions available.
The History pane in ArcGIS Pro with the Share Web Tool and Overwrite Web Tool functions available.
Article ID: 000028474
Software:
  • ArcGIS Pro
  • Portal for ArcGIS
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
