PROBLEM
The Select Layer By Attribute tool returns the opposite records of the query in ArcGIS Pro
Last Published: October 26, 2022
In ArcGIS Pro, attempting to select features in a map using the Select Layer By Attribute tool returns the opposite records of the query.
In this example, the query in the Select Layer By Attribute tool is to select the layer with the OBJECTID that equals to 12. However, the selected layers are those with the OBJECTID that do not equal to 12, as shown in the image below.
The layer with the OBJECTID that equals to 12 is not selected using the query in ArcGIS Pro.
Cause
The Invert Where Clause option is enabled in the Select Layer By Attribute tool. Thus, running the tool returns the inverse results of the query.
Solution or Workaround
To solve the issue, ensure the Invert Where Clause option is disabled before running the Select Layer By Attribute tool. Refer to ArcGIS Pro: Parameters for more information on the Select Layer By Attribute tool.
The Select Layer By Attribute tool window to be configured.
Alternatively, once the opposite record of the query is selected, use Switch Selection in the attribute table to deselect all the selected features and select all the deselected ones. In the Contents pane, right-click the feature layer, navigate to Selection, and click Switch Selection.
Selecting Switch Selection in the Contents pane.
Article ID: 000028570
Software:
  • ArcGIS Pro 3 0
  • ArcGIS Pro 2 8 x
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
