PROBLEM
The search result or feature attribute pop-up is not displayed in ArcGIS Web AppBuilder when using the Near Me widget
Last Published: March 9, 2021
In ArcGIS Web AppBuilder, the Near Me widget enables users to find features within a buffer of a defined address or location. When defining an address or location, the 'Search result' or 'Searched Location' pop-up window is displayed on the map.
Sometimes, the search result pop-up is not displayed for the found feature or location when defining a feature or location using the Near Me widget.
The pop-up for the found feature is not displayed on the map.
There are instances where users attempt to use the ‘Set location’ button in the Near Me widget to set a location on the map, but clicking the map fails, and a return message is displayed, 'Popups are not configured, results cannot be displayed.'
Pop-ups fail to display on the map, and returns a message, “Popups are not configured, results cannot be displayed.”
In a situation where the ‘Set location’ dialog box displays next to the cursor when hovering over the map, clicking the map only displays the Searched Location pop-up window. Users are unable to display the feature attribute pop-up window by clicking a feature on the map when the Near Me widget is active.
The Set location dialog box displays next to the cursor when hovering over the map.
Clicking the map only displays the Searched Location pop-up window.
Cause
The following are known causes for the issue:
  • The search result pop-up fails to display when the ‘Show pop-up for the found feature or location’ check box is not checked.
  • The return message is displayed when pop-ups are not enabled at the web map level, or the selected search layer configured in the Near Me widget settings does not have pop-ups configured.
  • The feature attribute pop-ups do not display when the ‘Set location’ button is not enabled in the Near Me widget.
Solution or Workaround
Depending on the cause, use one of the options below to resolve the issue.
Check the Show pop-up for the found feature or location check box
In ArcGIS Web AppBuilder, check the Show pop-up for the found feature or location check box in the Near Me widget settings to display the search result pop-up.
  1. In ArcGIS Web AppBuilder, on the Widget tab, click Set the widgets in this controller.
  2. On the Widget tab, hover over the Near Me widget, and click Configure this widget.
The Widget tab in ArcGIS Web Appbuilder showing the Configure this widget pencil icon to configure the Near Me widget
  1. In the Configure Near Me window, on the Search Source Settings tab, check the Show pop-up for the found feature or location check box, and click OK.
In the Configure Near Me window, check the Show pop-up for the found feature or location check box to display pop-ups when searching for a location in the Near Me widget.
  1. On the Widget tab, click Save to save the configurations.
The image below shows the Search result pop-up window is displayed when searching for a location in the Near Me widget in ArcGIS Web AppBuilder.
The Search result pop-up window is displayed when searching for a location in the Near Me widget.
Configure pop-ups for the layer at the web map level and ensure the selected search layer configured in the Near Me widget settings has pop-ups configured
  1. Log in to ArcGIS Online. Click Content > My Content.
  2. Browse to the web map referenced in the ArcGIS Web AppBuilder web app, click More Options The My Content More Options button to select Open in Map Viewer from the drop-down list., and select Open in Map Viewer.
  3. In Map Viewer, enable pop-ups for the layer to display the search result pop-up for the found feature or location on the map in ArcGIS Web AppBuilder when searching for a location using the Near Me widget.
  4. In the Contents pane, browse to the layer with pop-ups configured, click More Options The More Options button next to the layer to select Save Layer from the drop-down list., and select Save Layer.
  5. Click Save to save the web map.
  6. In ArcGIS Web AppBuilder, on the Widget tab, click Set the widgets in this controller.
  7. On the Widget tab, hover over the Near Me widget, and click Configure this widget.
  8. In the Configure Near Me window, on the Search Settings tab, in the Select search layers(s) section, click Set.
In the Select search layers(s) section, click Set to select layers.
  1. In the Select search layers(s) window, check the layer with pop-ups configured, and click OK.
The Select search layers window showing the checkbox to check the layer with pop-ups configured to be configured in the Near Me widget.
  1. In the Configure Near Me window, click OK.
  2. On the Widget tab, click Save to save the configurations.
Configure the Near Me widget settings to enable the Set location button
In ArcGIS Web AppBuilder, check the Set location button check box to provide a button to set the location on the map instead of only setting the location when the map is clicked. This enables users to click a feature on the map to view its feature attribute pop-up when the Near Me widget is active.
By default, the Set location button check box in the Near Me widget settings is unchecked. A Set location dialog box displays next to the cursor when the Near Me widget is active, and clicking the map only displays the Searched Location pop-up window.
  3. In the Configure Near Me window, on the Search Settings tab, check the Set location button check box, and click OK.
The Search Settings tab showing the Set location button check box to display the button in the Near Me widget.
The image below shows the Set location button displays next to the search box in the Near Me widget. When the Set location button is enabled, clicking the map to set a location displays the Searched Location pop-up window.
The Near Me widget showing the Set location button displays and the Searched Location pop-up window is displayed on the map.
The image below shows when the Set location button is not enabled in the Near Me widget, clicking a feature on the map displays the feature attribute pop-up.
The Near Me widget showing when the Set location button is not enabled, clicking a feature on the map displays the feature attribute pop-up.
Article ID: 000025192
Software:
  • ArcGIS Web AppBuilder
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
