PROBLEM
The Search hint text configured in web maps does not display in the Map widget in ArcGIS Experience Builder
First Published: July 6, 2023
Last Published: July 6, 2023
In some cases, the hint text configured on the item details page in the web map does not display in the Search box of the Map widget in ArcGIS Experience Builder.
The image below demonstrates the hint text configured in a web map.
The image of the example of a hint text set in a web map.
The image below shows the default hint text instead of the customized hint text is displayed in the Search box of the Map widget in ArcGIS Experience Builder.
The image of default hint text displayed in the Search box of the Map widget in ArcGIS Experience Builder .
Cause
This is by design. The customized hint text is displayed only if the map or layer with the customized hint text is selected from the drop-down menu in the Search box.
Solution or Workaround
Select the map or layer with the customized hint text from the drop-down menu in the Search box
  1. Open the ArcGIS Experience Builder project and navigate to the Search tool on the map.
  2. In the Search box, click the drop-down arrow.
  3. Select the map or layer with the customized hint text.
The image of the map with the customized hint text being selected to display the hint text in the Search box.
Add the Search widget to the ArcGIS Experience Builder project
If required, disable the Search tool in the Map widget before continuing with the workflow. In the Map widget pane, click Content, navigate to the Tools section, and toggle Search off.
The image of the Search tool being toggled off in the Map widget pane.
  1. Open the ArcGIS Experience Builder project and click the Insert icon.
  2. In the Insert widget pane, search for and drag the Search widget to the map.
The image of the Search widget being searched in the Insert widget pane.
  1. In the Search pane, click Content > New search source. Select the data source for the feature layer to search.
  2. In the Set layer source pane, edit the Label and Icon sections if necessary.
  3. Under Search options, configure the following parameters:
    1. For Select searching fields, select one or more fields to search in the layer.
    2. For Display fields, select one or more fields to display in the search result panel.
  4. Type the desired hint into the Hint box.
  5. Save and publish the project.
The image of the set parameters in the 'Set layer source' pane.
The image below shows the customized hint text displayed in the Search widget in ArcGIS Experience Builder.
The image of the hint text being displayed in the Search widget in ArcGIS Experience Builder.
Article ID: 000030711
Software:
  • ArcGIS Online
  • Portal for ArcGIS
  • ArcGIS Enterprise
  • ArcGIS Experience Builder
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
