PROBLEM
The scalebar or North arrow of an ArcMap Service is getting lost or cut off
The scalebar, the North arrow, or both cannot be seen or is cut off in the map image.
The following is an ArcMap Service image with cut off scalebars.
[O-Image] LostScaleBarOrig
Cause
This occurs when another acetate layer, such as a SIMPLEPOLYGONSYMBOL, overlaps the scalebar or the North arrow.
Solution or Workaround
Overlaying scalebars and North arrows with seperate acetate layers can not be done with ArcMap Server.
Notice, in the code below, the height and width of the SIMPLEPOLYGONSYMBOL acetate layer, or the box surrounding the copyright text, is 18 and 785 pixels respectively. The map contains two scalebars and the coordinates of both 452 3 and 619 3 that fall within the range of the SIMPLEPOLYGONSYMBOL.
<REQUEST>
<GET_IMAGE>
<PROPERTIES>
<ENVELOPE minx="-122.587093767496" miny="37.64239015" maxx="-122.255576232504" maxy="37.87395885" />
<IMAGESIZE height="449" width="786" />
<LAYERLIST >
<LAYERDEF id="0" visible="true" />
</LAYERLIST>
<BACKGROUND color="255,255,255" />
</PROPERTIES>
<LAYER type="acetate" name="theBottomBar">
<OBJECT units="pixel">
<POLYGON coords="0 1;1 18;785 18;785 1;0 1">
<SIMPLEPOLYGONSYMBOL fillcolor="255,255,255" boundary="true" boundarycolor="0,0,0" overlap="false" />
</POLYGON>
</OBJECT>
</LAYER>
<LAYER type="acetate" name="theCopyright">
<TEXT coords="3 3" label="Map created with ArcIMS - Copyright (C) 1992-2002 ESRI Inc.">
<TEXTMARKERSYMBOL fontstyle="Regular" fontsize="8" fontcolor="0,0,0" antialiasing="True" overlap="false" />
</TEXT>
</OBJECT>
</LAYER>
<LAYER type="acetate" name="theNorthArrow">
<NORTHARROW type="4" size="30" coords="20 35" shadow="32,32,32" angle="0" antialiasing="True" overlap="False" />
</OBJECT>
</LAYER>
<LAYER type="acetate" name="theScaleBar">
<SCALEBAR screenlength="78" coords="452 3" mode="geodesic" fontcolor="0,0,0" fontstyle="Regular" barcolor="128,128,128" scaleunits="miles" antialiasing="True" fontsize="9" barwidth="5" overlap="False" />
</OBJECT>
</LAYER>
</GET_IMAGE>
</REQUEST>
</ARCXML>
The solution is to avoid an overlap by implementing an option below.
  • Reduce the size of the overlapping acetate layer, to appear similar to this resulting image.
    [O-Image] ChangeBottomResult
    Here is a code sample. Notice that the width of the SIMPLEPOLYGONSYMBOL is reduced to 300.
    <REQUEST>
    <GET_IMAGE>
    <PROPERTIES>
    <LAYERLIST >
    </LAYERLIST>
    </PROPERTIES>
    <POLYGON coords="0 1;1 18;300 18;300 1;0 1">
    </POLYGON>
    </OBJECT>
    </LAYER>
    </TEXT>
    </OBJECT>
    </LAYER>
    </OBJECT>
    </LAYER>
    </OBJECT>
    </LAYER>
    <LAYER type="acetate" name="theScaleBar2">
    <SCALEBAR screenlength="78" coords="619 3" mode="geodesic" fontcolor="0,0,0" fontstyle="Regular" barcolor="128,128,128" scaleunits="kilometers" antialiasing="True" fontsize="9" barwidth="5" overlap="False" />
    </OBJECT>
    </LAYER>
    </GET_IMAGE>
    </REQUEST>
    </ARCXML>
  • Move the location of the scalebar or North arrow, to appear similar to this resulting image:
    [O-Image] ChangeScaleBarLoc
    Here is a code sample. Notice that the Y value of the coords has been increased to 20.
    <REQUEST>
    <GET_IMAGE>
    <PROPERTIES>
    <LAYERLIST >
    </LAYERLIST>
    </PROPERTIES>
    </POLYGON>
    </OBJECT>
    </LAYER>
    </TEXT>
    </OBJECT>
    </LAYER>
    </OBJECT>
    </LAYER>
    <SCALEBAR screenlength="78" coords="452 20" mode="geodesic" fontcolor="0,0,0" fontstyle="Regular" barcolor="128,128,128" scaleunits="miles" antialiasing="True" fontsize="9" barwidth="5" overlap="False" />
    </OBJECT>
    </LAYER>
    <SCALEBAR screenlength="78" coords="619 20" mode="geodesic" fontcolor="0,0,0" fontstyle="Regular" barcolor="128,128,128" scaleunits="kilometers" antialiasing="True" fontsize="9" barwidth="5" overlap="True" />
    </OBJECT>
    </LAYER>
    </GET_IMAGE>
    </REQUEST>
    </ARCXML>
Article ID:000006491
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
