PROBLEM
The registration fails if a previous version's registration code or file is used during the registration of ArcView or ArcEditor
When registering with a different version's registration number in ArcGIS Desktop 9.3, an "invalid registration number" message displays.
If an authorization file (.esu9) from a different version is used, a message like the following displays:
[O-Image]
Cause
This error may come up if an authorization file (.esu9) from a previous version of the software has been used. Authorization codes or files from different ArcGIS Desktop product versions cannot be used; for example, ArcView 9.2 codes cannot be used to register ArcView 9.3.
Solution or Workaround
To resolve the issue, register the product using an authorization code or authorization file specific to the version of software that has been installed.
Request an ESRI Authorization file for the version of ArcGIS Desktop installed at http://service.esri.com.
The single use registration or UNK number must already be acquired.
To request a single use registration or UNK number, contact ESRI Customer Service at 888-377-4575.
Article ID:000010155
Software:
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
