PROBLEM
The raster image shifts from the original location when adding control points
First Published: January 1, 2019
In some instances, when attempting to add control points to a raster image in ArcGIS Pro using the Add Control Points option, the image shifts from the original location.
Cause
This issue occurs because the Auto Apply option is enabled. By default, when clicking the Georeference icon in the Imagery tab, the Auto Apply option in the Adjust group is enabled. If this option is enabled, the image automatically shifts as the control points are added, removed, or modified. For more information about this option, refer to the following web help page, ArcGIS Pro Help: Adjust.
The Auto Apply option
Solution or Workaround
To resolve this issue, in ArcGIS Pro, disable the Auto Apply option and add all the required control points. After adding the control points, update the display by clicking the Apply option, and click Save.
User-added image
The following image shows the raster image and the control points are displayed on the original location on the map.
The raster image and the control points are displayed on the map
Article ID: 000019497
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
