PROBLEM
The Python parser in the Field Calculator returns incorrect results
In ArcMap, when the Python parser is used in the Field Calculator to carry out a division operation, integers are returned instead of decimals.
An example of the Python expression is as follows:
!VEHICLE_THEFT!/!POPULATION!
The division operation using the Field Calculator returns 0 for all fields.
[O-Image]
Cause
This is by design. Python 2.x is designed to return integers when dividing whole numbers regardless of the field type. For example, 1/9=0.
Solution or Workaround
In the attribute table, create a float type field. This allows Python to return a decimal in the result. After creating the new field, apply the Python script.
  1. Create a new field type as float in the attribute table.
    1. Open ArcMap.
    2. Right-click the selected layer in the Table Of Contents, and select Open Attribute Table.
[O-Image]
  1. Click the Table options drop-down, and select Add Field.
[O-Image] [O]
  1. In the Add Field dialog box, set the field name, and select Float as the field type, and click OK.
[O-Image]
  1. Apply the Python script.
    1. Right-click the new field, and select Field Calculator.
[O-Image]
  1. If a warning on calculating outside of an edit session displays, click Yes.
  2. In the Field Calculator, type the script highlighted below.
float(!FieldName1!/!FieldName2!)
 The code provided is for the input of the type float.
  1. Click OK.
[O-Image]
    Article ID: 000012400
    Software:
    • ArcMap 10 x
    Download the Esri Support App
    Related Information
    Discover more on this topic
    Get help from ArcGIS experts
    Contact technical support
    Go to download options
