PROBLEM
The Planarize Lines option is disabled in the Advanced Editing toolbar
First Published: December 9, 2019
In some instances, the Planarize Lines option is disabled while working with the Advanced Editing toolbar in ArcMap.
The Advanced Editing toolbar showing the Planarize Lines option disabled
Cause
The Planarize Lines option is disabled if the features selected in the map layout include polygon or point features. This option is available only when line features are selected, as it splits selected line features where they intersect and removes overlapping line segments.
Solution or Workaround
To resolve this issue in ArcMap, clear the selected features using the Clear Selected Features Clear Selection tool and select only line features.
To avoid confusion, Esri recommends turning off the polygon or point layer before selecting the line features in the Table Of Contents. Refer to ArcMap: Turning a layer on or off for more information.
The image below shows the Planarize Lines option is enabled and can be used to split the lines.
The Planarize Lines option is now enabled
Article ID: 000022366
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
