PROBLEM
The Paste Special option is disabled in ArcGIS Pro
First Published: November 19, 2020
Last Published: July 20, 2023
In ArcGIS Pro, it is possible to copy and paste features in a feature class to another. In some instances, when attempting to paste selected features, the Paste Special option is disabled. When pressing Ctrl+Alt+V, the Paste Special window is not displayed.
The Paste Special option disabled in ArcGIS Pro.
Cause
The map view is inactive. This is shown by the gray color of the map view's tab.
Solution or Workaround
To resolve the issue, complete the steps below:
Ensure the features to be copied are selected before performing the following workflow. Refer to ArcGIS Pro: Select features interactively for more information.
  1. In ArcGIS Pro, click the map view tab to activate it. The map view tab's color turns blue.
The Map view tab color turns dark blue.
  1. On the ribbon, click the Edit or Map tab.
  2. In the Clipboard section, click Copy. The Paste Special option is enabled.
The Paste Special option is enabled in ArcGIS Pro.
Article ID: 000024559
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
