PROBLEM
ArcGIS QuickCapture allows users to capture locations, field conditions, and photos, with quick access to the camera icon on the top-left corner of each button in a project. However, in some instances, the camera icon does not display on some of the buttons, as demonstrated in the image below.
Depending on the cause, use one of the following options to resolve the issue.
Configure the button settings to enable the take photo option in ArcGIS QuickCapture Web Designer
Note: Press and hold Shift on the keyboard to select and configure multiple buttons at once.
Enable the editing capabilities of the project’s hosted feature layer in ArcGIS Online
For the take photo option to be enabled in the ArcGIS QuickCapture project, the hosted feature layer of the project must be editable. Log in to ArcGIS Online with the same credentials used in ArcGIS QuickCapture, and check the Enable editing. check box in the hosted feature layer settings. Refer to ArcGIS Online: Allow others to edit for steps to do this.
The image below shows the camera icon displayed on the buttons of the project in ArcGIS QuickCapture.
Article ID: 000026028
Get help from ArcGIS experts
Start chatting now
