PROBLEM
The option to store credentials is not visible when adding secured services in Portal for ArcGIS
Credentials for services used in Portal for ArcGIS can be stored to enable future usage without having to log in each time the map is opened. However, there are certain cases where the option to store credentials is not visible and the credentials for the services cannot be stored.
Cause
  • The services are secured with web-tier authentication, for example, Integrated Windows Authentication (IWA). This is by default.
  • The services are inaccessible by Portal for ArcGIS. This may occur if the service is blocked by a firewall, or the services proxy is not configured correctly.
  • The SSL certificate used by the service is not trusted by Portal for ArcGIS.
Solution or Workaround
Depending on the cause, the workarounds provided are applicable.
Article ID: 000015387
Software:
  • Portal for ArcGIS
  • ArcGIS Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
