PROBLEM
The following warning message is produced at execution of the OLE DB to Table tool: "The application is not licensed to create or modify schema for this type of data".
The OLE DB to Table tool will let you attempt to write to an INFO table. The option to write to an INFO table should be disabled as dBASE tables are the only valid option for ArcView.
Article ID:000003149
Get help from ArcGIS experts
Download the Esri Support App
