PROBLEM
The Notebook tab is unavailable in ArcGIS Online
Last Published: August 19, 2021
When attempting to access ArcGIS Notebooks in ArcGIS Online, the Notebook tab is unavailable, as shown in the image below.
The ArcGIS Notebooks in ArcGIS Online window showing the Notebook tab unavailable.
Cause
The organization member is assigned a non-administrator default or custom role with insufficient privileges to create and edit notebooks in ArcGIS Online.
Solution or Workaround
Update the member's role to a default Administrator or custom role with the privilege to create and edit notebooks
Only an organization's administrator can perform the following workflows.
To create notebooks with Advanced runtime, enable the Advanced notebooks option in the Premium Content section under the General privileges settings.
Enable the Create and edit notebooks option for the custom role to allow member to create and edit interactive notebooks.
The image below shows the Notebook tab available in ArcGIS Online.
Users can access ArcGIS Notebooks in ArcGIS Online through the Notebook tab.
Article ID: 000026213
Software:
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
