PROBLEM
The newly created table view doesn't display in the specified directory
After creating a Table View, it does not appear in ArcCatalog.
Cause
Table views are the table equivalent of a feature layer. The Make Table View tool creates a table in memory. ArcCatalog does not display these tables, but they can be used as inputs to other geoprocessing tools in the session in which you are working. Once you exit the application, the tables in memory are removed.
Solution or Workaround
Instructions provided show how to convert a table view to a table within a personal geodatabase or a folder.
  1. Start ArcToolbox.
  2. Click Conversion Tools > To Geodatabase.
  3. Double-click 'Table to Geodatabase (multiple)'.
  4. Click the 'Input Table' dropdown list and highlight and click Table View.
  5. For 'Output Geodatabase', specify a folder or personal geodatabase. Click OK.
Article ID:000008711
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
