PROBLEM
When searching for an address using the Near Me widget, clicking a returned result displays empty details. The following widget images show empty search result details returned for ‘Grenshaw bus routes’.
This issue occurs when one of the following is not configured correctly at the web map level:
Depending on the cause, use one of the options below to resolve the issue.
Add a pop-up title to the hosted feature layer
To add a pop-up title, open the web map in Map Viewer, and configure the pop-up of the hosted feature layer. Refer to ArcGIS Online: Configure pop-ups for complete steps.
Ensure the default field value name remains as default
When configuring pop-ups using the Add field name or expression button in Step 4 of the documentation, ensure the default field value name used in the pop-up title remains as default.
Article ID: 000023078
Get help from ArcGIS experts
Download the Esri Support App
