PROBLEM
The My Content tab is unavailable in Portal for ArcGIS and ArcGIS Online
First Published: January 4, 2024
Last Published: January 4, 2024
When attempting to access the My Content tab on the Content page in Portal for ArcGIS or ArcGIS Online, the My Content tab is not available. Consequently, the 'New item' and 'Create app' options are also unavailable on the Content page.
Home page without New item option, Create apps option and the My Content tab
Cause
The role assigned to the user does not have the required privileges to create or share items with the organization. In Portal for ArcGIS, only the User, Publisher, and Administrator roles have the privilege to add new items and create apps. Refer to Portal for ArcGIS: General privileges for additional information regarding the general privileges assigned to the default roles.
In ArcGIS Online, only the User, Publisher, Facilitator, and Administrator roles have the privilege to add new items and create apps. Refer to ArcGIS Online: General privileges for additional information regarding the general privileges assigned to the default roles.
Solution or Workaround
Only an organization's default administrator or a member with administrative privileges can perform the following workflow.
  • In Portal for ArcGIS, change the user's default role to User, Publisher, or Administrator. Refer to Portal for ArcGIS: Change member roles for instructions to change the organization's member roles on Portal for ArcGIS.
  • In ArcGIS Online, change the user's default role to User, Publisher, Facilitator, or Administrator. Refer to ArcGIS Online: Change member roles for instructions to change the organization's member roles on ArcGIS Online.
The image below shows the Content page when accessed by a user with the required privileges. The My Content tab, along with the 'New item' and 'Create app' options are available.
Home page with the New item option, Create app option and the My Content tab
Article ID: 000031658
Software:
  • ArcGIS Online
  • Portal for ArcGIS
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
