PROBLEM
When viewing a mosaic layer in ArcGIS Pro, the layer displays on a map with a checkerboard pattern.
In certain circumstances, when zoomed in, the mosaic layer displays on the map.
Depending on the cause, use one of the following workarounds to resolve the issue.
Repair the mosaic dataset path
Repair the broken mosaic dataset paths in ArcGIS Pro. The broken mosaic dataset paths can be repaired by utilizing ArcGIS Pro geoprocessing tools. Refer to ArcGIS Pro: Repairing paths in a mosaic dataset for instructions and more information.
Use the Build Overviews tool
In ArcGIS Pro, run the Build Overviews tool after running the Define Overviews tool. The Define Overviews tool allows a user to specify additional parameters for the overviews and requires executing the Build Overviews tool afterward. Follow the workaround below to define and generate overviews for the mosaic dataset by utilizing the Build Overviews tool.
The image below shows the mosaic layer with the same zoom level, which displays the missing raster image after running the Build Overviews tool.
Article ID: 000024286
Get help from ArcGIS experts
Start chatting now
