PROBLEM
The Merge tool returns null values in ArcGIS Pro
Last Published: November 1, 2022
In some instances, when using the Browse function in the Merge tool to search for and add input datasets from the local computer file location, null values are returned in the merged results.
The Browse function in the Merge tool in ArcGIS Pro.
The image below shows null values are returned in the attribute table after running the Merge tool.
The null values are returned in the attribute table.
Cause
This is a known limitation of the Merge tool in ArcGIS Pro.
Solution or Workaround
Use one of the methods below to resolve the issue.
Select the input datasets from the drop-down list
  1. In ArcGIS Pro, add data to the Contents pane. Refer to ArcGIS Pro: Add data to a project or ArcGIS Pro: Add layers to a map or scene for instructions.
  2. On the top ribbon, click the Analysis tab > Tools.
  3. In the Geoprocessing pane, search for and select Merge (Data Management Tools).
  4. In the Merge pane, click the Parameters tab.
  5. Click the drop-down list next to the Browse icon, and select the desired input dataset for Input Datasets. Repeat the same step until all the required datasets are included. Alternatively, click the Add Many drop-down button to load data from the map.
The Add Many drop-down button next to Input Datasets.
Alternatively, drag the datasets from the Contents pane, and drop them in the Input Datasets section in the Merge pane.
  1. Fill in the output name for Output Dataset. Configure the Field Map section accordingly, and check the Add source information to output option. Click Run.
Alternatively, click the Reset The Reset button next to Field Map in the Merge pane. button after adding feature classes and before running the Merge tool.
The Merge tool Geoprocessing pane to select the input datasets and fill in the output name.
The image below shows the correct values are returned in the attribute table after running the Merge tool.
The attribute table with the correct values  returned.
Use the Append tool
In ArcGIS Pro, use the Append (Data Management) tool to resolve the issue. Refer to ArcGIS Pro: Append (Data Management) for more information.
Article ID: 000026750
Software:
  • ArcGIS Pro 2 8 x
  • ArcGIS Pro 2 7 x
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
