PROBLEM
The Mask Kind parameter for polygon and line layers does not display in the Feature Outline Masks tool
First Published: March 11, 2020
In ArcGIS Pro, the Mask Kind parameter does not display in the Feature Outline Masks tool when polygon and line layers are used. Instead, it displays when point and annotation layers are used.
The images below show the Feature Outline Masks pane with a polygon layer as the input layer, and the Mask Kind parameter is not displayed.
Polygon layer
The images below show the Feature Outline Masks pane with a point layer as the input layer, and the Mask Kind parameter is displayed.
Point layer
Cause
This is expected behavior for the tool. The Mask Kind parameter only displays when annotation and point layers are used.
Solution or Workaround
As a workaround, use the batch mode in the Feature Outline Masks tool to display the Mask Kind parameter when the input layer contains both polygon and line layers. The parameter displays because in batch mode, the tool does not pre-validate data to determine the kind of mask to select. Alternatively, use the Buffer or Minimum Bounding Geometry tools. Refer to ArcGIS Pro: Buffer (Analysis) or ArcGIS Pro: Minimum Bounding Geometry (Data Management) for steps and more information.
To open and run a tool in batch mode, refer to ArcGIS Pro: Batch geoprocessing. The images below show the Feature Outline Masks running in batch mode.
Batch Feature Outline Masks
Batch mode
Article ID: 000022737
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
