PROBLEM
The linear units of measurement are unavailable with offset tracing in ArcGIS Pro
First Published: September 10, 2024
Last Published: February 10, 2025
In ArcGIS Pro, when the ‘Trace with offset’ check box is checked in the Trace Options dialog box, the Units drop-down menu displays angular units, such as Decimal Degrees (DD), Degrees Minutes Seconds (DMS), and Right Ascension (RA) as options, instead of linear units, such as mile (mi), feet (ft), US feet (ftUS), yard (yd), kilometer (km), and meter (m).
The Trace Options window
Cause
The map in the ArcGIS Pro project uses the geographic coordinate system. A geographic coordinate system records locations in angular units. Refer to ArcGIS Pro: Coordinate systems, map projections, and transformations for more information.
Solution or Workaround
Change the map's coordinate system to a projected one. Refer to ArcGIS Pro: Set the coordinate system for instructions. In this example, the coordinate system is changed to 'NAD 1983 Wisconsin TM (Meters)'.
The new coordinate system set in the Map Properties dialog box
The image below shows the menu displaying linear unit options after changing the map's coordinate system to a projected one.
The linear units options displayed in the Trace Options dialog box
Article ID: 000033455
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
