PROBLEM
The legend text items are partially displayed in ArcGIS Pro
First Published: February 8, 2023
Last Published: February 8, 2023
When a legend is added to a layout, the overflow symbol The overflow symbol is displayed, and the legend text items are partially displayed in ArcGIS Pro.
The legend text items are partially displayed, and the overflow symbol appears on the layout.
Cause
This is by design. The legend text items are set to word wrap by default, causing the overflow symbol to display and the legend text items to partially display on the legend. This happens when the text items are too long and exceed the legend space.
Solution or Workaround
Use one of the following methods to resolve the issue.
Configure the word wrapping settings
  1. Open the project in ArcGIS Pro.
  2. In the Contents pane, right-click Legend and click Properties from the context menu.
The Properties option in the context menu
  1. In the Element pane, click Legend > Legend Arrangement Options.
  2. Expand the Word wrapping node and uncheck the Labels and Descriptions check boxes.
The Element pane
  1. Click Save to save the changes.
The Save button
The image below shows the overflow symbol no longer displays on the legend.
The legend with no overflow symbol appearing after configuring the word wrapping settings
Change the feature layer's name
Changing the feature layer's name in the Contents pane reflects changes in the legend. Follow the workaround below to change the feature layer's name.
  2. In the Contents pane, right-click the respective feature layer and click Properties to open the Layer Properties window.
  1. On the General tab, for the Name parameter, rename the feature layer to a simplified or shorter name. In this example, the Light_Rail_Lines_in_Portland feature layer is renamed to Light Rail Lines.
  2. Click OK.
The Layer Properties window
The Save button
The legend text items with no overflow symbol appearing after the feature layer is renamed to a simplified form.
Article ID: 000029256
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
