PROBLEM
The Join Features tool in the Analysis widget of Web AppBuilder for ArcGIS fails to function in ArcGIS Enterprise 10.5.1
First Published: April 8, 2020
The Join Features spatial analysis tool does not run in the Web AppBuilder for ArcGIS Analysis widget.
Cause
A problem in the underlying JavaScript prevents the tool from working in the Analysis widget.
This problem is associated with a known defect, BUG-000106282
Solution or Workaround
Upgrade to ArcGIS Enterprise 10.6 or later.
If this problem is still encountered after upgrading, please contact Esri Technical Support.
Article ID: 000023102
Software:
  • ArcGIS Web AppBuilder
  • Portal for ArcGIS
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
