PROBLEM
The Import Feature Class button is not available in ArcGIS Pro 3.0
First Published: July 29, 2022
Last Published: July 20, 2023
After upgrading to ArcGIS Pro 3.0, the Import Feature Class button is no longer available when right-clicking the file geodatabase in the Catalog pane to import a feature class into the geodatabase. Only the Import Feature Class(es) button is available, and this does not have the functionality to edit the output feature class name.
The Import Feature Class button is no longer available when right-clicking the file geodatabase in the Catalog pane in ArcGIS Pro 3.0.
Cause
This is by design. The Import Feature Class button by right-clicking the file geodatabase in the Catalog pane has been removed from ArcGIS Pro 3.0.
Solution or Workaround
Use one of the methods below to resolve the issue.
Search for and select the Feature Class To Feature Class tool
  1. In ArcGIS Pro 3.0, click the Analysis tab on the top ribbon > Tools.
  2. In the Geoprocessing pane, search for and select Feature Class To Feature Class.
  3. In the Feature Class To Feature Class pane, click the Parameters tab.
  4. Select the feature class to import in Input Features, and fill in the new feature class name for Output Name. Click Run.
The Feature Class To Feature Class pane in ArcGIS Pro 3.0.
Run the Feature Class To Geodatabase tool
Before running the Feature Class To Geodatabase tool, ensure the Allow geoprocessing tools to overwrite existing datasets option is checked. Navigate to ArcGIS Pro, and click Project > Options > Geoprocessing and check the Allow geoprocessing tools to overwrite existing datasets check box under the Set options for running geoprocessing tools and script section. Refer to ArcGIS Pro: Feature Class To Geodatabase (Conversion) for more information.
The ‘Allow geoprocessing tools to overwrite existing datasets’ option is checked under the 'Set options for running geoprocessing tools and script' section.
  1. In ArcGIS Pro 3.0, right-click the file geodatabase in the Catalog pane.
  2. Click Import > Feature Class(es).
  3. In the Feature Class To Geodatabase pane, click the Parameters tab.
  4. Select the feature class to import in Input Features. Click Run.
The Feature Class To Geodatabase pane in ArcGIS Pro 3.0.
Use the Export Features function
  1. In the Contents pane of ArcGIS Pro, right-click the desired feature class and click Data > Export Features.
  2. In the Export Features window, click the Parameters tab.
  3. Select the feature class in Input Features and edit the new database or feature class name for Output Feature Class. Click OK.
The Export Features window in ArcGIS Pro 3.0.
Article ID: 000028106
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
