PROBLEM
The graticule disappears when rotating the contents of a data frame
When rotating the contents of a data frame, the graticule disappears. The data frame is using a geographic coordinate system.
Solution or Workaround
Instead of using a geographic coordinate system, set your data frame to use the Plate Carree projected coordinate system.
  1. Open the Data Frame Properties dialog box and select the Coordinate System tab.
  2. Select Predefined > Projected Coordinate Systems > World > Plate Carree (world) from the list of coordinate systems.
  3. Click OK to close the Data Frame Properties dialog box.
  4. Rotate the data frame to the desired angle using the rotation tools on the Data Frame Tools toolbar.
Article ID:000003230
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
