PROBLEM
The GPS metadata fields are empty when creating data in ArcGIS Field Maps
Last Published: June 27, 2024
When collecting and creating data in the ArcGIS Field Maps mobile app, the GPS metadata fields are empty. ArcGIS Field Maps cannot record the latitude, longitude, altitude, and other GPS metadata values for certain features, despite the GPS receiver functioning correctly and transmitting data. The inability to record the GPS metadata impacts the accuracy and usability of the collected spatial data.
The attribute table below shows the empty GPS metadata fields for certain data collected in ArcGIS Field Maps.
The empty GPS metadata fields for certain records
Cause
  • The point features are manually repositioned away from the coordinates provided by the GPS signal.
  • The point features are snapped to another existing point.
Solution or Workaround
To record the GPS metadata accurately, configure the ‘Manual location’ or ‘Snapping’ settings when preparing the map in ArcGIS Field Maps Designer or within the ArcGIS Field Maps mobile app.
Disable manual location entry during data collection in ArcGIS Field Maps Designer
  1. Log in to ArcGIS Field Maps Designer via ArcGIS Online.
  2. On the Maps page, browse to and click the map card.
  3. On the left of the page, click App settings > Collection.
  4. In the Collection section, under Manual location, select Block manual location.
The configured Manual location setting in ArcGIS Field Maps Designer.
  1. Click Save changes The Save changes icon. on the top-right corner of the page.
Disable feature snapping in ArcGIS Field Maps Designer
  4. In the Collection section, toggle Snapping off to disable snapping.
The configured Snapping option in ArcGIS Field Maps Designer.
Disable feature snapping in the ArcGIS Field Maps mobile app
  1. Log in to the ArcGIS Field Maps mobile app via ArcGIS Online.
  2. On the top-left corner, tap Profile The Profile icon..
  3. Tap Collection Settings > Snapping.
  4. Toggle Snapping off to disable snapping.
The configured Snapping option in the ArcGIS Field Maps mobile app.
Article ID: 000032464
Software:
  • ArcGIS Field Maps Android
  • ArcGIS Field Maps iOS
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
