PROBLEM
The GeoTagged Photos To Points tool generates an empty output in ArcGIS Pro
First Published: May 13, 2022
Last Published: May 18, 2022
In ArcGIS Pro, running the GeoTagged Photos To Points tool generates an empty output, and in some instances, the following warning message is returned, "WARNING 000117: Warning empty output generated."
The GeoTagged Photos To Points tool runs successfully but returns a warning message.
In a situation where the tool executes successfully, the output features do not contain any X, Y, or Z coordinate information and are not displayed on the map.
The GeoTagged Photos To Points tool runs successfully but the output features are not displayed on the map.
Cause
  • The input geotagged photo file format such as HEIC or PNG is unsupported. The output layer’s attribute table is empty when the input geotagged photo file format is unsupported.
  • The output features do not contain X, Y, or Z coordinate information when the photos in the input folder are not geotagged.
Solution or Workaround
Use supported geotagged photo file formats
Use supported geotagged photo file formats such as JPG or TIFF for the GeoTagged Photos To Points tool to generate the desired results.
In some instances, empty outputs are generated without any warning messages when the input folder is stored on a cloud storage, such as OneDrive. This is a known limitation. Refer to Problem: ArcGIS Pro and Cloud Storage Services for more information.
Article ID: 000027648
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
