PROBLEM
The Geoprocessing Wizard in ArcMap is not updating shapefile area and length attributes
Shapefiles produced by the GeoProcessing Wizard in ArcMap do not have length or area attributes calculated for the new shapes. If the input shapes have these attributes, the output will inherit the existing values of these attributes.This also applies to Geoprocessing tools and shapefiles in ArcGIS 9.
Cause
This is a known issue with the GeoProcessing Wizard. The shapefile data structure does not support the automatic calculation of spatial attributes, such as area and length. The problem is that these attributes could be in any field, and the wizard could end up overwriting something that you do not want changed.
Solution or Workaround
There are two work-arounds for this problem.
  • Output the geoprocessing results to a geodatabase feature class. The Shape_area and Shape_length fields are correctly calculated.
  • Recalculate the shapefile area and length field values. An example of how to do this is provided in the ArcGIS Desktop Help. On the Index tab type "tables" and double-click 'calculating field values'.
Article ID:000005517
Software:
  • ArcMap 9 x
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
