PROBLEM
The flow direction arrow symbol from a map service does not display when added to a web map in Portal for ArcGIS
Flow direction arrow symbols applied to an individual Map Service layer do not display when the layer is added to a web map in Portal for ArcGIS. Instead, thick black lines appear in the web map.
The image below displays what happens when an individual Map Service layer using flow direction arrow symbols is added to a web map. It is apparent that no symbols are rendered:
However, when the same Map Service layer is opened in ArcMap, flow direction arrow symbols display correctly as shown in the image below:
Map service URL opened in ArcMap
Cause
This is a known limitation. When added individually, Map Service layers containing flow direction arrow symbols are not supported and will not draw as expected when added to a web map. Web browsers do not have the ability to draw complex line symbols. If there are multiple line layers or line layers with complex symbols, the lines are downgraded to simple line symbols. For more information, refer to ArcGIS Server Web Help: Define Symbology.
Solution or Workaround
As a workaround, add the complete Map Service URL to the web map in Portal for ArcGIS instead of only adding the individual layer that contains flow direction arrow symbols. For more detailed steps, refer to Portal for ArcGIS Web Help: ArcGIS Server web service.
If flow direction arrows are not visible on the web map, zoom in to the area of interest.
The image below shows flow direction arrow symbols displaying correctly when the whole Map Service URL is added to the web map in Portal for ArcGIS:
Map service url added in web map
Article ID: 000018910
Software:
  • ArcMap
  • Portal for ArcGIS
  • ArcGIS Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
