PROBLEM
The Fitting Strategy tab is not available in ArcGIS Pro
First Published: May 28, 2024
Last Published: July 2, 2024
In ArcGIS Pro, when the label placement properties are configured in the Label Class pane, the Fitting Strategy tab is not available; only the Position and Conflict Resolution tabs are displayed, as shown in the image below. In addition, some of the label placement properties on the Position and Conflict Resolution tabs are not available.
The label properties on the Position tab and the Fitting Strategy tab is not displayed.
The label properties on the Conflict Resolution tab and the Fitting Strategy tab is not displayed.
Cause
The Standard Labeling Engine is activated. The Standard Labeling Engine has a smaller set of available properties to be configured and Fitting Strategy properties are only available when the Maplex Label Engine is activated. Therefore, the label placement properties provided by the Maplex Labeling Engine are not displayed.
Solution or Workaround
  1. Open the ArcGIS Pro project.
  2. In the Contents pane, click the desired feature layer.
  3. On the Feature Layer tab set, click the Labeling tab.
  4. In the Map group, click More and click Use Maplex Label Engine to enable the engine.
The Use Maplex Label Engine option enabled.
The images below show the Fitting Strategy The Fitting Strategy tab icon. tab and the label placement properties for the Position and Conflict Resolution tabs provided by the Maplex Label Engine displayed in the Label Class pane in ArcGIS Pro.
The label properties for Position as provided by the Maplex Label Engine and the Fitting Strategy tab is displayed.
The label properties for Conflict Resolution as provided by the Maplex Label Engine.
Article ID: 000032741
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
