PROBLEM
The Feature Dataset option is disabled in ArcGIS Pro 2.6
First Published: October 29, 2020
Last Published: October 29, 2020
In ArcGIS Pro 2.6, the Feature Dataset option in the Catalog pane is disabled when attempting to create a new feature dataset.
The following image shows the disabled Feature Dataset option.
Image of the disabled Feature Dataset option in ArcGIS Pro 2.6
Cause
This is known behaviour after the ArcGIS Pro 2.6 update, which renders users with a Basic license unable to select the Feature Dataset option. This issue is logged by Esri as a defect. For more information, refer to BUG-000133417 and BUG-000132678.
Solution or Workaround
Use one of the methods below to resolve the issue.
Use the Create Feature Dataset tool
  1. In ArcGIS Pro 2.6, click the Analysis tab > Tools.
  2. In the Geoprocessing pane, search for and select Create Feature Dataset (Data Management Tools).
  3. Populate the required fields in Parameters. Click Run
Image of the Create Feature Dataset (Data Management Tools)window.
The following image shows a new feature dataset is created.
Image of the new feature dataset is created.
Upgrade to a Standard or Advanced license for ArcGIS Pro on the machine
Upgrade to a Standard or Advanced license to enable the Feature Dataset option for selection in ArcGIS Pro. Refer to ArcGIS Pro: How to get ArcGIS Pro licenses for more information.
The following image shows the Feature Dataset option is enabled in the Catalog pane in ArcGIS Pro 2.6 with a Standard or Advanced license.
Image of the Feature Dataset option is enabled.
Article ID: 000024260
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
