PROBLEM
The feature class alias is not preserved when transferring a feature class from a file geodatabase to an enterprise geodatabase
If a feature class does not have an assigned alias, ArcGIS uses the feature class name as the alias on-the-fly. When the feature class is transferred from a file geodatabase to an enterprise geodatabase, the alias also changes to reflect the fully qualified feature class name in the database (<database>.<schema>.<feature_class>). This may look like the feature class alias is not preserved during the transfer.
Cause
The feature class (or table) alias is the alternative name of a feature class. It is the name displayed when a feature class is added to the map in ArcGIS clients. When creating a feature class, an alias can be assigned to the feature class, which becomes a property of the feature class. If an alias is not specified, ArcGIS uses the feature class name as the alias on-the-fly. The Describe ArcPy function can be used to check the alias name of a feature class:
desc = arcpy.Describe(<feature_class>)
print ("AliasName:", desc.aliasName)
If a feature class does not have an assigned alias, desc.aliasName returns a blank field. The alias in the feature class properties window is what ArcGIS generates on-the-fly for the feature class to use when added to a map. In a file geodatabase, the 'on-the-fly' alias looks identical to the feature class name. In an enterprise geodatabase, the feature class name is fully qualified with the database (except Oracle) and with the schema name appended in front of the actual feature class name. The on-the-fly alias reflects the fully qualified name too. As a result, when transferring a feature class which utilizes an on-the-fly alias, it appears that the actual feature class alias is not preserved, however, in fact the feature class does not have a specified alias and the on-the-fly alias just stays in sync with the feature class name.
Solution or Workaround
Use one of the following options to resolve the issue:
  • Assign an alias to the feature class in the file geodatabase. The specified alias does not change during the transfer and it is the same in the enterprise geodatabase.
  • Manually change the feature class alias in the enterprise geodatabase after the transfer.
  • For batch processing and automation, consider using the ArcPy AlterAliasName function and iterating through feature classes stored in a workspace.
Article ID: 000018179
Software:
  • ArcMap
Download the Esri Support App
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
