PROBLEM
The 'Failed to check sharing process status' error is returned when publishing a feature layer from ArcGIS Pro to ArcGIS Online
First Published: March 25, 2020
Last Published: June 9, 2020
Publishing a feature layer to ArcGIS Online using the 'Share As Web Layer' option from ArcGIS Pro fails, and returns the following error message:
Error:
Image of the error message
Cause
The ArcGIS Online organization name contains the non-breaking space ( ) HTML code. Thus, ArcGIS Pro fails to publish the feature layer to ArcGIS Online.
In some cases, the non-breaking space ( ) HTML code is manually added to the organization name to create extra spaces in the gallery title and the organization page.
Solution or Workaround
Complete the steps described below to resolve the issue.
  1. Log in to the ArcGIS Online organization with administrator privilege.
  2. Remove the non-breaking space ( ) HTML code from the Name field in Organization profile. Refer to ArcGIS Online: Configure general settings for more information on configuring the organization's settings.
  3. Click Save.
Image of the Configure general settings window.
Article ID: 000022967
Software:
  • ArcGIS Pro
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
