PROBLEM
The Export option is inactive in the ArcGIS Survey123 website
Last Published: May 11, 2022
The Export option is inactive in the ArcGIS Survey123 website, disabling the option to export survey data.
Image showing Export option disabled
Cause
  • The option to export the survey to other formats is not enabled in ArcGIS Online.
  • The organization member's assigned role has insufficient privileges to export data.
Solution or Workaround
Choose one of the methods below to resolve, depending on the cause.
Enable the option to export the survey feature layer to other formats
  1. Log in to ArcGIS Online with the same organization credentials used in ArcGIS Survey123.
  2. Click the Content tab, navigate to the survey folder in the Folders section, and click the survey feature layer to open the item details page. In this example, the feature layer is HOA Emergency Preparedness Survey.
Navigating to the Folders section in the Content tab and clicking the survey feature layer to open the item details page.
  1. Click the Settings tab, scroll to the bottom of the page, and check the Allow others to export to different formats option under the Export Data section.
Checking the Allow others to export to different formats option
  1. Click Save.
  2. Navigate to the ArcGIS Survey123 website, and refresh the page.
Assign a role with sharing privileges
Assign the organization member a User or custom role with sharing privileges.
Only administrators have sufficient privileges to change and configure organization members' roles.
The Role drop-down in the Members tab
  • Refer to ArcGIS Online: Configure member roles for more information on assigning a custom role. Enable the Share with groups, Share with organization, and Share with public options under the General privileges section when assigning privileges for the new custom role.
Enablin the sharing privileges for the custom role
The Export option is no longer disabled, as shown in the image below.
The Export option is active
Article ID: 000023086
Software:
  • ArcGIS Survey123 Website
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
