PROBLEM
The Exploratory 3D Analysis tools are not available in ArcGIS Pro
First Published: October 10, 2023
Last Published: July 19, 2024
In ArcGIS Pro, when clicking to expand the Exploratory 3D Analysis drop-down list, only the Object Detection tool is shown in the list.
The Exploratory 3D Analysis drop-down list
Cause
This is expected behavior when opening the tools list on a map. The Exploratory 3D Analysis tools can only be fully utilized in a scene. 2D maps lack depth and elevation properties in comparison to local or global scenes. By default, tools that are unusable for 2D maps are hidden.
Solution or Workaround
To resolve the issue, convert the map to a local or global scene.
  1. In ArcGIS Pro, on the ribbon, click the View tab.
  2. In the View group, click Convert and select either To Global Scene or To Local Scene. In this example, To Global Scene is selected. A new 3D map is displayed.
Convert the map to a 3D scene
  1. On the ribbon, click the Analysis tab.
  2. In the Workflows group, click the Exploratory 3D Analysis drop-down list.
The image below shows the full list of Exploratory 3D Analysis tools.
The Exploratory 3D Analysis list
Article ID: 000031227
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
