ERROR
The Enable Editor Tracking tool returns an error when using a mosaic dataset in ArcGIS Pro
First Published: May 5, 2020
Last Published: September 4, 2025
Error Message
When running the Enable Editor Tracking tool on a mosaic dataset in ArcGIS Pro, the following error message is returned.
Error:
Error 001218: No editor tracking property selected for operation.
Error 001218
Cause
This is a known limitation. The error message is returned when there are no pre-existing editor tracking fields specified. Additionally, if the ‘Add fields’ option is selected, the names of the fields to be added must be provided by filling in values for the Creator Field, Creation Date Field, and Last Edit Date Field parameters.
Solution or Workaround
The Enable Editor Tracking tool does not auto-generate the editor tracking fields, these field names and must be specified by the user.
  1. In ArcGIS Pro, navigate to View > Geoprocessing.
  2. In the Geoprocessing pane, search for and select the Enable Editor Tracking tool.
  3. Configure the Parameters tab.
    1. Select input for Input Dataset.
    2. Specify the fields for Creator Field, Creation Date Field, and Last Edit Date Field.
    3. Check the Add fields check box.
    4. Click Run.
Article ID: 000023291
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
