PROBLEM
The Elevation Profile widget in ArcGIS Experience Builder does not highlight the next connected features for selection
First Published: March 25, 2025
Last Published: August 14, 2025
When selecting a line segment using the Elevation Profile widget in ArcGIS Experience Builder, the next connected line segment is not highlighted for selection, even though the widget setting is enabled and configured correctly.
The image below shows the Elevation Profile widget only highlighted the selected line segment in ArcGIS Experience Builder.
The Elevation Profile widget highlighting only the selected line segment in ArcGIS Experience Builder
Cause
This issue occurs because the layer used in the web map is a map image layer that references a map service. Map services render map content as images and do not make individual feature geometry, attributes, or symbology available for querying or editing.
Solution or Workaround
Ensure that a feature service is used. Feature services provide individual feature geometries, attributes, and symbology for displaying, querying, and editing vector data in web maps. It specifically allows access to individual geographic features within a dataset. For instructions, refer to ArcGIS Pro: Share a web feature layer using the default configuration.
The image below shows the selected line segment highlights the next line segment for selection in the ArcGIS Experience Builder Elevation Profile widget.
The selected line segment highlights the next selectable line segment in the ArcGIS Experience Builder Elevation Profile widget
Article ID: 000035446
Software:
  • Portal for ArcGIS
  • ArcGIS Enterprise
  • ArcGIS Experience Builder
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
