PROBLEM
The Editor widget is empty in ArcGIS Experience Builder
Last Published: January 22, 2024
When launching a web experience from ArcGIS Online, the Editor widget does not show any editable layers and returns the following error:
Error:
No editable layers found.
The Editor widget appears empty in ArcGIS Online
When launching the web experience in Portal for ArcGIS, the widget is completely empty, as shown in the following image.
The Editor widget appears empty in Portal for ArcGIS
Cause
  • All layers specified in the widget are not editable. The Editor widget uses layers from a web map referenced in the Map widget inserted into the web experience. Even if the web map is shared publicly, the layer it references must be editable for use.
  • The user viewing the web experience has a Viewer role. The layer is non-editable to users with a Viewer role even if editing is enabled on the layer.
Solution or Workaround
The user interface for the workflows are similar in Portal for ArcGIS and ArcGIS Online.
The following image demonstrates the Editor widget working as expected.
The Editor widget working as expected
Article ID: 000031809
Software:
  • ArcGIS Online
  • Portal for ArcGIS
  • ArcGIS Enterprise
  • ArcGIS Experience Builder
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
