PROBLEM
The drop-down list does not display in an ArcGIS Survey123 Connect XLSForm
Last Published: May 6, 2022
In some instances, after copying survey questions from an XLSForm and pasting them in another in ArcGIS Survey123 Connect, the drop-down button of some cells of the pasted survey questions do not display a list of options.
The drop-down button is not working.
Cause
This issue occurs because the pasted survey questions in the XLSForm still reference the original Data Validation Source from which the survey questions are copied. In most cases, when copying survey questions from a republished XLSForm in ArcGIS Survey123 Connect, the Data Validation Source is preserved even after pasting the survey questions in another XLSForm.
Solution or Workaround
To circumvent this issue, ensure the pasted survey questions in the XLSForm reference the intended Data Validation Source. To do so, follow the steps described below:
In this example, the questions type in the 'survey' worksheet must reference the list of Field Types in the 'types' worksheet.
  1. Open the XLSForm. In the survey worksheet, select the cell, or the entire column (if necessary), with the disabled drop-down button.
A screenshot of the XLSForm worksheet.
  1. Click Data > Data Validation in the Data Tools section.
Data validation in XLSForm.
  1. In the Data Validation dialog box, under the Settings tab, click the drop-down button under Allow, and select List.
  2. Click the upload button Upload button. next to the Source text box.
  3. Click the types worksheet. Under Field Types, highlight the desired cell range to add the list to the Source box.
  4. Click OK to save the Data Validation settings.
Data validation dialog box and the worksheet.
  1. Ensure that clicking the drop-down button displays the list of options.
The drop-down button displays desired list of options.
  1. Save the XLSForm.
Article ID: 000020679
Software:
  • ArcGIS Survey123 Connect
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
