PROBLEM
In ArcGIS Experience Builder, the Description setting is unavailable in the Bookmark pane when attempting to add a description to a bookmark using a card, list, or gallery template in the Bookmark widget.
By default, the Description setting is only available for the slide templates of the Bookmark widget. Refer to ArcGIS Experience Builder: Bookmark widget for information regarding the availability of the Description setting in the Bookmark widget.
Note: The Bookmark widget currently has three different types of slide templates.
The map below shows the Bookmark widget using the slide template with descriptions in ArcGIS Experience Builder.
As an alternative, the advanced template can be used to replicate the functionality of the Description setting in the Bookmark widget. The advanced template includes a default text box that enables users to add descriptions. The workflow below is the steps to change the bookmark template to the advanced template.
Note: On the Bookmark widget, click the image to add the desired image to each bookmark.
The map below shows the Bookmark widget using the advanced template with a set image and description in ArcGIS Experience Builder.
Article ID: 000033194
Get help from ArcGIS experts
Start chatting now
