PROBLEM
The date format for pop-ups and printed maps in ArcGIS Online Map Viewer does not reflect the account settings
First Published: November 30, 2022
Last Published: December 27, 2022
The date format used by an ArcGIS Online account does not reflect the user interface on pop-ups or maps printed to PDF in ArcGIS Online Map Viewer.
The image below shows the 'Number and date format' in 'My settings' in ArcGIS Online is set to Australia. However, the map printed in Map Viewer follows the United States MM/DD/YYYY date format instead.
The Number and date format in My settings set to Australia The printed map from ArcGIS online follows the US date format
Cause
This behavior is a single sign-on (SSO) authentication method issue, whereby the default settings, license allocations and other configurations are not reflected in the ArcGIS Online user interface.
Solution or Workaround
Use the following workflow to update the 'Number and date format' setting in ArcGIS Online:
  1. In ArcGIS Online, click the user profile name at the top of the site and click My settings.
Navigating to My settings in ArcGIS Online
  1. On the General tab, navigate to Language, number, and date format and click Update.
Updating the Language, number, and date format
  1. In the Language, number, and date window, select a different locale for the Number and date format parameter. In this example, Great Britain - Great Britain is selected.
  2. Click Save.
Selecting a different locale for the Number and date format parameter
  1. Click Update again under Language, number and date format and select the initial locale for the Number and date format parameter. In this example, Australia - Australia is selected again.
  2. Click Save.
Selecting the initial locale for the Number and date format parameter
The image below shows a printed map with the Australian DD/MM/YYYY date format. The date is 01/12/2022.
The printed map from ArcGIS online follows the Australian date format
Article ID: 000028766
Software:
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
